Author Topic: Getting really bad fireflies with backlit trees and Corona Renderer  (Read 6046 times)
RobH2
  • Who is staring at the sea is already sailing a bit
    • NVision4D
I realize that it's difficult for you to diagnose without seeing something but I thought I'd just do a quick post in case one of you said, "oh yea, just  do 'xyz' and they will go away."
I have a scene that is backlight by a rising sun in the scene that's in your face. Imagine watching a sunrise. The sun is already above the horizon. The trees I have in the foreground have terrible fireflies all around the edges of them. I'm using Corona Render, latest daily build. Is this common and are there accepted methods to mitigate this?
ForestPack Pro 6.3.1, RailClone 4.2.13, 3ds Max (Max 2024), GIGABYTE X570 AORUS x570 Master Motherboard, RTX4090, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, Sabrent Rocket NVMe 4.0 M.2 drives
Re: Getting really bad fireflies with backlit trees and Corona Renderer
« Reply #1 on: March 10, 2017, 12:24:09 pm »
As you've pointed out, it's really hard to say what might be causing it in your case and we're not Corona renderer experts, but I would suggest you to check the Max sample intensity value (in case of 0 it's disabled, in case of greater values than 100 lowering this value is highly recommendable - usually the default value of 20 works fine).
Also high glossiness values of used material(s) might lead to this effect (lowering material's glossiness should help to reduce sun reflections). A possible option to avoid it is to disable reflection visibility for Corona Sun (or the used light source) under Visibility - Visible in reflections.
Hope that helps.
RobH2
    • NVision4D
« Reply #2 on: March 10, 2017, 07:25:28 pm »
Thanks Michal, i appreciate the suggestions. I've disabled 'Visible in Reflections' and it helped a lot. I appreciate the response.
