Author Topic: Accessing details of start / end / evenly pieces from default.  (Read 3289 times)
Alex.S
What would be the most optimal way to do this? Say for example I want to know the size of the start and end piece during my default pieces?
I've tried various methods and they all seem to be very costly and inconsistent. I don't think it's actually possible right now I think if they can be set by Marker Data.
Re: Accessing details of start / end / evenly pieces from default.
« Reply #1 on: August 23, 2022, 10:42:27 am »
HI,
I'm assuming that you're not able to export the X Size attribute of the segments wired to the start and end input? Could you let me know a little more info about what you'd like to achieve?
Cheers,
Alex.S
« Reply #2 on: August 25, 2022, 11:01:35 am »
If I do that, then it basically doubles the computation time, mostly I guess because I am using RC Spline markers to set the end piece perhaps? Setting just a constant value works wonders, but if I could do something like RCMarkerData[id, position] to return marker data at some other point on the spline that would help a lot.
Also I often run into issues when setting up patterns and I want to do something different to the end piece based on that pattern. Say for example we have a chequered on / off pattern, and I want to make the end piece the same or different colour as the last default piece, I can't get that information reliably (although I do have ways of estimating it with like 60-70% success, i often need to just manually set these via a Marker value)
I'm a bit short on time atm, is that an ok explanation?
« Reply #3 on: August 25, 2022, 02:03:03 pm »
Hello Alex,
Thanks for the additional info. I'll pass this on to the dev team and see what the options are.
Cheers!
