Author Topic: Roof Issues  (Read 2980 times)
Bobby Parker
Roof Issues
« on: August 16, 2016, 06:47:54 pm »
I am having the hardestt time putting a roof together. Some parts of the roof works and other do not. Here is a screen recording.hardest
http://screencast-o-matic.com/watch/cDjDDEiLkd
Re: Roof Issues
« Reply #1 on: August 16, 2016, 08:13:45 pm »
This happens when the Spline and the Surface are exactly the same size. Unfortunately it's a know issue and at the moment the only solution is to make the surface larger than the spline. Alternatively you can not use a surface and just rotation the RC object so that it's aligned to the pitch of the roof. I think you've seen this script, but it can really speed up this process.
Many Thanks,
Bobby Parker
Re: Roof Issues
« Reply #2 on: August 16, 2016, 09:41:37 pm »
I see, thanks for the quick response. I will try your suggested workarounds.
Bobby Parker
Re: Roof Issues
« Reply #3 on: August 16, 2016, 10:34:14 pm »
Worked perfectly, thanks!
Re: Roof Issues
« Reply #4 on: August 17, 2016, 10:36:20 am »
My pleasure, glad we could help out. :)
