Author Topic: Acquiring licence when not on LAN  (Read 2832 times)
IT1371
« on: April 09, 2019, 12:46:40 pm »
So I have this situation which I kinda figured out but its not very optimal.
You see, I have a couple of RC and FPP floating license on one of my PCs. When connected over wifi or LAN I can access them with no problem and everything works just fine.
Now when i'm not in the office, let say in school or at home, I just access the license server by changing the IP address to the DNS address I have (port configured in router and works) in the "Change License Mode" tool and I can easily do my projects when outside the office.
But is a hassle to keep changing that. Is there a way to make it automatic? Or some file I can edit and add 2 different IP addresses for my PC to scan when starting up RC or FPP?
Re: Acquiring licence when not on LAN
« Reply #1 on: April 11, 2019, 10:45:12 am »
I‘m afraid, that currently there‘s no automatic detection of the current network, but this parameter "LicservHost" is stored under following keys:
[HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\Forest Pack Pro]
[HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\RailClone Pro]
and changing this value, for example by „importing“ prepared .reg files might be an option for you.
