Author Topic: Setting up a parquet floor  (Read 21308 times)
Anthony Lester
« on: January 24, 2014, 11:33:49 am »
If anyone could help it would be most appreciated.
Having looked at the parquet floor tutorials on the site I was inspired to start using RC for our flooring, I have used the Linear 1S right from the beginning and am fairly used to the parameters in that but working with the Array 2S I am having problems. Whilst I understand the principles putting it into practice is proving quite tricky.
I have attached two image one showing the parquet flooring style that I am trying achieve and a second image of what I have been able to put together.
Could anyone advise as to a way of achieving this?
Thanks in advance.
Anthony
Re: Setting up a parquet floor
« Reply #1 on: January 24, 2014, 12:45:19 pm »
Hi Anthony,
There are a few ways this style can be created To do it in a single style use two compose operators to create sets of horizontal and vertical planks. The vertical planks are relatively straightforward but the horizontal ones take a little more work, to position them use Fixed Y-Translation to move one above the other and then left and right padding to make them overlap. A tip here is that if the sum of a segment's left and right padding is >= its width, then the segment will disappear, so to resolve this split the segment's width measurement between the current and preceding segment's padding. To illustrate, if a 300mm long segment has a left padding value of -150mm, the preceding segment would need a right padding of -150mm too. Below is a screengrab of the node tree for this technique.
Alternatively a much simpler approach is to nest one RailClone object inside another. To use this technique create a simple RailClone object with the number of segments you need for each panel, in my example I used 3. Add the material ID randomiser to this style too.
Then create your floor style and select this RailClone object as a segment. Make sure you turn on "Nest" from the segment's properties to allow the Material IDs to be re-seeded every time the segment is used. The finished style should look like this:
I've attached a file so you can have a look at both these techniques in more detail.
Hope that helps,
Kind regards,
Anthony Lester
« Reply #2 on: January 24, 2014, 12:51:02 pm »
Thanks Paul, as ever it's great to get such a quick and informative response from you guys!
I will take a look through the files and let you know if I have any further problems.
Anthony
Anthony Lester
« Reply #3 on: January 24, 2014, 02:37:58 pm »
Paul,
Once again thanks for the tips, and file, I have it sorted now. I think I had the idea right but didn't know how to implement it, with your help I have now resolved it.
Just one final question (for the time being :) ) I notice that you have two numeric parameters for the expand and z rotation, how do you implement in the array, by default there doesn't appear to be any sockets for those 'variables'?
Thanks again
Anthony
« Reply #4 on: January 24, 2014, 04:59:12 pm »
Hi Anthony,
Glad I could help out  :).
To reveal these inputs just right click on the node and go to the Export menu, here you'll see a list of all the parameters that can be exported. This will work for most nodes.
Anthony Lester
« Reply #5 on: January 27, 2014, 10:59:07 am »
Thanks Paul, got it.
BR
Anthony
