Author Topic: User Library is not showing up  (Read 4980 times)
suppenhuhn
« on: August 15, 2019, 12:01:33 pm »
Hi!
I'm forced to use 3ds Max 2018 but got a problem that all my UserLibraries created for RailClone ( with Max 2015 ) are not showing up in Max 2018 ? My libraries are subfolders in the "default-folder" documents/railclone/libs - so they should appear in the library browser or am i wrong?
And when adding the subfolder path via: library browser -> file -> preferences ... there is only a empty folder showing up within the library browser but no items in it.
« Last Edit: August 15, 2019, 12:05:17 pm by suppenhuhn »
Re: User Library is not showing up
« Reply #1 on: August 15, 2019, 01:09:05 pm »
Sorry to hear, you're facing these troubles. Would you mind to double-check the value of the User's Libraries entry of the following system registry key (does the path match)?
Computer\HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\LibraryDir
Thanks in advance for any further details on this issue.
suppenhuhn
« Reply #2 on: August 15, 2019, 01:34:55 pm »
Awesome, fixed it !!!
No, it didn't match - there was a different path in there, thank you !! :)
« Reply #3 on: August 15, 2019, 02:05:47 pm »
You're welcome. Glad to hear, that it helped ;)
