Author Topic: Seamless mapping  (Read 6628 times)
Re: Seamless mapping
« Reply #15 on: November 18, 2021, 05:17:47 pm »
Thank You, Paul.
Yes, that is close enough to my workflow. Minimum polycount, the texture remains...
It could be difficult to track for Newbie Users but it will do the job.
I did an initial generator to mimic real-world mapping so I had the initial MapSize input Parameter as a ratio divider which will always keep the initial map size.
If my current project allows me I`ll look for this generator and make a Macro so we can share this with Community. I believe a lot of users had similar needs.
You can post just your last post as a separate Topic or even better as the new tutorial.
In a meantime, you can show the algorithm to the dev. team so they can code it.  ;D 8)
« Last Edit: November 18, 2021, 08:09:27 pm by Dragan »
