Author Topic: Extracting Clipping plane X and Y max dimensions  (Read 3329 times)
Anthony Lester
« on: April 06, 2021, 02:06:38 pm »
Is there a way to extract the x and y attributes of a clipping plane used to generate an array.
I would like to use this information to specify a fixed Y dimension of an segment so that it scales to the full height of the clipping plane, similar to the Default segment rule of scale.
I would also then like to use the info to use within an expression to determine the aspect ratio of the clipping spline so that I can determine a specific material ID.
The clipping spline always be rectangular, it will in effect be a window frame
Thanks in advance
Anthony
Re: Extracting Clipping plane X and Y max dimensions
« Reply #1 on: April 06, 2021, 02:19:55 pm »
Sorry, I didn't see your attachment but here is an example.
Edit: either way I can`t open it due to the Max version. Can you please downgrade it to 2018.
« Last Edit: April 06, 2021, 02:25:00 pm by Dragan »
Anthony Lester
« Reply #2 on: April 06, 2021, 02:56:14 pm »
That's the ticket, I had tried the x/y spline length in a n expression but not as a nested array
Many thanks
Anthony
« Reply #3 on: April 06, 2021, 03:05:59 pm »
Glad to help.
Since you can set the Default mode to Scale only on the "X-axis", to prevent unnecessary segment count, please, pay attention to Side segments ("Y-axis") and try to calculate Fixed Y size for those elements.
« Reply #4 on: April 06, 2021, 06:47:03 pm »
... like this...
« Last Edit: April 07, 2021, 07:51:14 am by Dragan »
Anthony Lester
« Reply #5 on: April 06, 2021, 07:05:24 pm »
Yes That is what I have done, I have also been able to get the aspect ratio as well from the two expressions and using that to select a range of materials.
