Author Topic: Adding model to user libary  (Read 4848 times)
yossivida
« on: December 12, 2016, 05:32:42 pm »
Hello i trying to add model to the user libaries i did same as the tuturial : http://docs.itoosoft.com/display/RAILCLONE/Customizing+the+Library
but still i got an error // i attached a screen shot
thank you
Re: Adding model to user libary
« Reply #1 on: December 13, 2016, 12:18:27 pm »
Please double check, you're picking the RC object (build using your custom style) from such scene (not any model used within that style - these will be automatically embedded, when imported into a new scene).
yossivida
« Reply #2 on: December 13, 2016, 01:31:24 pm »
hey this i the model...
i attached a screen recoreder of what i do...
http://sendvid.com/1bu11950
« Reply #3 on: December 13, 2016, 01:46:01 pm »
Thanks for provided video. The "handhold" object is an Editable Poly object - not a RailClone object required by our Library Browser. As mentioned previously, it's designed to handle RC styles - not just geometry components.
Hope that clears it up.
Best regadrs,
yossivida
« Reply #4 on: December 13, 2016, 01:54:16 pm »
Thanka for the quick responses.  There is any tuturial how to make max objects to rc object? That i can work with rail clone with my models?
« Reply #5 on: December 14, 2016, 03:55:41 pm »
Hi, there is not a direct way to convert a mesh to RailClone, because you must define each one of the pieces, and how they are assembled in the final object.
This is the basis of parametric objects, and process may be more or less complex, depending of the object.
I suggest you take a look to the RailClone Getting Starting guide. It describes along several chapters everthing you need to create RC objects.
You can also find many tutorials on the website. Building a masonry wall is the most basic one.
