Author Topic: RailClone Color Bump Map Issue  (Read 3317 times)
archaeotect
« on: September 14, 2018, 11:11:56 pm »
Hi!
I'm trying to setup a VRayMtl with Railclone Color maps. The maps work fine except in the Bump Map slot. No bump effect applied, it doesn't matter what or how many submaps are plugged into RailClone Color or if they are VRay Normal maps or traditional black and white ones. As soon as I use any of these maps on its own, the bump works fine, so it isn't a problem with lighting, UVs or anything I can think of. As soon as I put them in a RailClone Color map slot again - zero Bump. No other setting (Tint etc. ) is enabled/changed.
Re: RailClone Color Bump Map Issue
« Reply #1 on: September 17, 2018, 11:15:07 am »
Thanks for reporting. I can confirm this issue. We will look into it.
archaeotect
« Reply #2 on: September 17, 2018, 08:01:31 pm »
Thanks. Please keep us updated. If there's no quick fix, I'll revert everything to MultiSubTex and use material IDs.
« Reply #3 on: September 18, 2018, 07:53:11 am »
Probably there will be no quick(this week) fix so please feel free to use other methods. Multitexture seems to work too.
