Author Topic: feature request: advanced Bend mode  (Read 13734 times)
harumscarum
    • harumscarum's portfolio
« on: November 12, 2014, 12:02:58 pm »
wonder if possible to make Bend mode treat segment as bounding box
i mean that horisontal beams are placed correctly so i want also vertical posts also straighten
or it is possible in any other way?
xpp_nd_ruphus
    • Portfolio
Re: feature request: advanced Bend mode
« Reply #1 on: November 12, 2014, 01:36:10 pm »
i think you should just correct path
« Last Edit: November 12, 2014, 01:40:11 pm by xpp_nd_ruphus »
« Reply #2 on: November 13, 2014, 12:54:09 pm »
Thanks for bringing this to our attention. We're currently looking into ways RailClone can handle these situations but in the meantime, if your spline is flat on the Z Axis, you should be able to turn Off Properties > Deform > Bend for the fence panel segment. If the slope is gradual you may find turning on Stepped mode is enough to follow the spline. Our libraries suffer from the same problem, these should be fixed too in the next update.
Many thanks,
IM1808
« Reply #3 on: January 09, 2025, 10:38:44 am »
Hi, the subject is old but that is possible now ? i have a fence that i want to keep in one mesh and i would like this one follow the surface terrain or line curve (X,Y,Z space) with vertical constraint but not bend. Like there is a new line beetween the evenlys, corner, start, end.
« Reply #4 on: January 10, 2025, 09:33:38 am »
Using the Normalize Spline modifier with the Linear Segments option enabled on the base spline and adjusting the Seg Length parameter to match the Evenly Distance should achieve the desired result.
