Author Topic: ERROR LOADING MATERIAL LIBRARY  (Read 8514 times)
RO3902
« on: January 10, 2025, 11:34:46 am »
Hi All,
Apologies if this topics been discussed many times, but i'm going insane trying to sort this. I have tried to relocate the libraries to one shared location on the network. The issue i'm having is i keep getting "Error loading material library: S:\Resources\3D_OBJECT_LIBRARY\Itoo\RailClone Pro\..\..\matlib\corona.mat" I have changed the registry files as shown in a few other posts on here, but still get the message. Any help would be appreciated, or a way to just change everything back to default.
Thanks in advance
Re: ERROR LOADING MATERIAL LIBRARY
« Reply #1 on: January 10, 2025, 11:48:45 am »
I'm sorry to hear that you are facing trouble with it. Please double-check the specified path - the RailClone library path should include the default1 folder. In your case:
S:\Resources\3D_OBJECT_LIBRARY\Itoo\RailClone Pro\lib\default1
I hope that helps, and please let us know if everything is working fine, or if you are still facing trouble with it. Thanks in advance.
RO3902
« Reply #2 on: January 10, 2025, 12:06:08 pm »
Hi Michal,
Thanks for the reply. I have edited the reg to the following:
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro]
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\LibraryDir]
"RailClone Library"="S:\\Resources\\3D_OBJECT_LIBRARY\\Itoo\\RailClone Pro\\lib\\default1"
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\MacroDir]
"Library"="S:\\Resources\\3D_OBJECT_LIBRARY\\Itoo\\RailClone Pro\\macros"
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\MatlibDir]
"Materials"="S:\\Resources\\3D_OBJECT_LIBRARY\\Itoo\\RailClone Pro\\matlib"
[HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\TexturePaths]
"1"="S:\\Resources\\3D_OBJECT_LIBRARY\\Itoo\\RailClone Pro\\maps"
But no luck at all. Railclone still throws the error back. The folders/files are all in the location specified.
kind regards
« Reply #3 on: January 10, 2025, 12:27:35 pm »
At first sight, these look correct. It might be that you changed it within the following registry key:
but within the:
[HKEY_LOCAL_MACHINE\Software\Itoo Software\RailClone Pro\LibraryDir]
it points to another location? The priority order is Environment Variables > HKLM > HKCU.
