RailClone => RailClone Pro (*) => Topic started by: Lee H on May 23, 2022, 01:02:17 pm
I have a tiled floor i need to create as per the image attached.
The version i am working on seems to be close, it is still wrong and i cannot understand how to fix this.The pattern has to be a mirror of the colour. Black against White, on X its fine but Y isnt
Any ideas ?
Hi.
It looks like you're nearly there. Try the following
- Clone the existing Sequence node and swap the order of its inputs
- Wire the two Sequence nodes to a third Sequence node and then connect that to the Default input
- Change the 3rd Sequence nodes Mode to Increment on Y.
Legend - thankyou
