Author Topic: Stadium Roof with defined inner AND outer broundaries  (Read 2581 times)
junglejuz
« on: May 20, 2022, 10:15:29 am »
Hi. I've been looking at the free tutorial file for creating a stadium and would like to use the roof railclone object. My problem is that I need to define the outer and inner boundaries of the roof, as they are non-uniform. The screenshot shows splines defining the boundaries. Is there a way of adapting the script so that the roof will conform to both boundaries?
Thanks in advance for any help.
Justin
Re: Stadium Roof with defined inner AND outer broundaries
« Reply #1 on: May 20, 2022, 05:19:47 pm »
Hi Justin,
At present I'm afraid there isn't an easy way in RailClone to create geometry between two paths. As a workaround though you might find the technique shown in this thread helpful: https://forum.itoosoft.com/railclone-pro-(*)/curved-sloped-
cladding/
Best
junglejuz
« Reply #2 on: May 21, 2022, 09:20:58 am »
thanks i'll look at that.
With an average 2 year development cycle, I'm assuming this is something that isn't likely to be implemented any time soon, if at all?
« Reply #3 on: May 23, 2022, 09:30:47 am »
An array that uses two splines in this way has been on our list for a while, but I'm afraid at this point I don't have any idea if or when it might be implemented.
Thanks for understanding,
