Author Topic: overlapping corners elements  (Read 4018 times)
lukx
    • lukxCGI
« on: January 05, 2016, 04:46:15 pm »
Is there anyway I can avoid overlaping geometry in corners:
link to scene: https://www.dropbox.com/s/adhpsnsyr39lgx8/overlaping.max?dl=0
lukx
    • lukxCGI
Re: overlapping corners elements
« Reply #1 on: January 05, 2016, 05:31:23 pm »
« Reply #2 on: January 05, 2016, 07:21:59 pm »
Please find attached a revised style that fixes the corner issue. I've made the following changes:
  • Changed the Z Alignment of all segments to Center. Other Axes are set to Automatic.
  • If you want to adjust the wall in relation to the Base Spline you can use the Generator's Y Offset property.
  • Reset the Corner segment's X Rotation to 0 degrees.
  • Turned off Generator > Properties > X Corner > Align to Path, This will stop the corner segment rotating 45 degrees on the corner which is why I removed the rotation in the previous step.
  • Turned on Generator > Properties > X Corner > Extend to Side. This will ensure the corner extends to the bottom row.
Many thanks!
lukx
    • lukxCGI
« Reply #3 on: January 05, 2016, 09:00:21 pm »
Big Thanks Paul !
