Author Topic: nested railclone objects and corona 8 problems  (Read 2727 times)
JG_archviz
    • JG
« on: August 06, 2022, 02:05:30 pm »
Hello
I recently found myself in some troubles using corona 8. In v7 everything worked fine. But rendering in corona v8 some railclone objects mess up if you rendering a "frame sequenz"
When rendering I use Sergo Pogosyan Batch Camera Render to render different cameras and different frames for changed sun-postion or other reasons.
Before Corona 8 i had no problems with latest Railclone-Pro objects. But in Corona 8 i can't render a sequenz or selection of frames continuesly. The Railclone Objects which contains nested Railclone Objects will break and render vairous railcone arangements.
That only happens (as far as i can recognize) to nested Railclone Objects.
Attached some Pictures describing the problem. It is no problem when just a single Frame rendering is started - then everything is renderen correct. But to render multiple frames, i always have to stop rendering and then restart rendering at the next frame.
It seems that the error shows that main railclone object doesn't follow the segments order when rendering the next frame.
The main Railclone Object is organizing the whole fassade, while the nested railclone objects are defining one area of the facade.
Those nested railclone objects might contain other nested railclone-segments.
JG_archviz
    • JG
Re: nested railclone objects and corona 8 problems
« Reply #1 on: August 06, 2022, 02:06:25 pm »
here are additional images describing the nested railcone objects
« Reply #2 on: August 08, 2022, 11:31:26 am »
Does it help to turn off Display > Use Instancing Engine for the nested RailClone objects?
JG_archviz
    • JG
« Reply #3 on: August 10, 2022, 03:06:20 pm »
Sorry was on vacation.
Need to check if that helps. will tell you latest next week!
JG_archviz
    • JG
« Reply #4 on: August 22, 2022, 03:42:55 pm »
Finally found time to test it.
Yes turning off instancing engine on all Railclone Objects helped and it rendered good.
Still weird, that it was no problem at all before Corona 8.
