Author Topic: align posts  (Read 5031 times)
MC4031
align posts
« on: November 14, 2016, 04:59:45 pm »
I don't  understand why my posts do not align with the staircases
I have to test into vertical but doesn't work
Can you help me?
Thank you
Re: align posts
« Reply #1 on: November 14, 2016, 05:33:29 pm »
The Deform - Vertical mode doesn't perform as expected, because your RC object has its local axis rotated as shown on attached screen-shot (specifically the rotation over X axis causes that problem). Setting the rotation to 0º (Z axis is orientated vertically) will fix it (generally it's recommendable to have RC objects aligned to World coordinates system to avoid similar problems). That'll have influence over all Segments / Generators in your style (the Rotation of involved Segments should be reset).
MC4031
Re: align posts
« Reply #2 on: November 14, 2016, 05:57:15 pm »
oh thanks ! i didnt' see :)
MC4031
Another problem
« Reply #3 on: November 15, 2016, 01:36:42 pm »
I succeeded has to give the adjustments.
But when I put the barriers that does not stick with the posts.
Why?
Re: align posts
« Reply #4 on: November 15, 2016, 01:57:15 pm »
Instead of the Deform - Stepped mode, I would suggest you to use the Vertical one with defined Flat Bottom value (for example 10cm as on attached screen-shot should be fine). Attaching modified scene, hope you'll find it useful.
Best regadrs,
MC4031
Re: align posts
« Reply #5 on: November 15, 2016, 02:00:56 pm »
thank you very much ! And for angles is it normal that it does not stick?
Re: align posts
« Reply #6 on: November 16, 2016, 03:55:02 pm »
Usual approaches to solve these problematic parts are to add a small fillet (Corner - Fillet Radius) or modify the Base Object (add a short horizontal part). Hope you'll find it useful.
