Author Topic: Saving Global Parameters to Library Object  (Read 2593 times)
« on: November 10, 2022, 07:47:16 pm »
I have a lot of issues with custom RC Presets because global parameters can`t be saved in the library. I`m referring to Use Segment Material, Curve Steps, Display Mode, and Use Instancing Engine...
For Generator to work properly a lot of specific combination of parameters has to be adjusted properly.
Users often fail to set these parameters, which causes the generator not to work.
I hope the new beta will start soon and something can be done about this metter.
Regards
Re: Saving Global Parameters to Library Object
« Reply #1 on: November 11, 2022, 10:10:23 am »
Ok. We'll see what can be done, because probably not all in some cases is desirable to import global parameters.
We started to work in RailClone 6, but first beta will take some time yet.
We'll dedicate full time to it, once that Forest 8 is complete (we continue working on the latest reported issues).
« Reply #2 on: November 11, 2022, 05:16:12 pm »
Ok, at least dependable parameters like Use Material & Instancing Engine.
Should I look for my notes for beta testing?   8) ;D
