Author Topic: More spline in one Generator  (Read 2587 times)
RealViz
    • RealViz
« on: January 04, 2022, 12:07:46 pm »
is there any way to assign multiple Splines to one generator? Or do I need to create another Generator each time? Thanks
Re: More spline in one Generator
« Reply #1 on: January 04, 2022, 12:12:02 pm »
At present generators only support one spline object. However, you can  attach the splines together so that it contains several sub-splines.
I hope that helps,
RealViz
    • RealViz
« Reply #2 on: January 04, 2022, 12:14:26 pm »
Thank you, of course you can. However, handling larger scenes is more difficult afterwards. Too bad the Combine operators don't work for spline.
