Author Topic: Randomize percentage mode bug in RC 6.1.1  (Read 2881 times)
nubo
« on: July 14, 2023, 04:18:52 pm »
I've just installed the newest 6.1.1 version and after opening one of the current projects I've noticed that some RC objects won't show (but they are greenlit as 'Object correct').
After a quick analysis I've managed to narrow down the issue to the "Random" parameter in "Percentage" mode wired to the Fixed Scale Transform node .
It looks like the parameter generates some incorrect values.
After switching to "Integer" mode everything generates fine.
EDIT // Switching to "Float" mode also fixes the problem. //
Before the update the parameter also worked fine in percentage mode.
See the attached simplified scene.
RC 6.1.1
3DS Max 2023.3
Windows 10
Przemek
NUBO
« Last Edit: July 14, 2023, 04:23:35 pm by nubo »
Re: Randomize percentage mode bug in RC 6.1.1
« Reply #1 on: July 15, 2023, 09:58:46 am »
Thanks for reporting it. This bug was not spotted while the beta.
We just released RC 6.1.2 with the fix.
Regards,
