Author Topic: Alignment on multiple sub-splines with Extend to Size  (Read 2630 times)
GO6827
« on: October 07, 2022, 12:03:33 pm »
Using a A2S and multiple sub-splines with extend to size, i cannot get the same alignment across the entire RC object. Can it be done without moving the sub-splines?
Thanks!
Re: Alignment on multiple sub-splines with Extend to Size
« Reply #1 on: October 07, 2022, 01:06:39 pm »
If you need a precise placement I find it easier not to use the Extend X/Y Size to area option. Instead, you can manually position it where you need it and then apply the clipping operation separately. Here's how to adapt the scene:
  • Turn off Properties > General > Clipping Area > Extend X/Y Size to Area
  • Enter a value in Properties > Geometry X Size and Y Size to create an array large enough to cover the area.
  • Move the entire RC object over the clipping spline so that it's positioned as you would like.
  • Open the Base Objects roll-out and reselect the clipping spline from the scene to update the clipping operation
That should help.
GO6827
« Reply #2 on: October 07, 2022, 01:25:38 pm »
Offcourse, thanks alot Michal, works like a charm  :)
« Reply #3 on: October 07, 2022, 03:10:31 pm »
You're welcome. I'm glad to hear, that it helped ;)
