Author Topic: Roof Tiles Macro: Padding don't work  (Read 3363 times)
Michael Betke
« on: March 12, 2021, 09:41:53 am »
I try to modify one of the roof presets using different tiles.
It works somehow. Now I need to tweak the gaps between the tiles using padding parameter.
But no value works. There is no change no matter what number I enter.
Re: Roof Tiles Macro: Padding don't work
« Reply #1 on: March 12, 2021, 09:45:31 am »
Hi Michael,
Are you using the Padding parameters found in the Macro's properties? The will override anything that you enter on the Segment itself.
Paul.
Michael Betke
« Reply #2 on: March 12, 2021, 10:05:39 am »
Only the Tile Side padding. There is no for other directions.
« Reply #3 on: March 12, 2021, 12:38:15 pm »
If You could attach Your max file and tell what You are trying to achieve- we could take a deeper look.
Michael Betke
« Reply #4 on: March 12, 2021, 01:08:44 pm »
I just try to use the Roof Macro to build a simple roof with two verges.
The tiles to the left and right fit well. But The need to be more shifted towards each other. Like 5cm or so.
I attached the file. :)
« Reply #5 on: March 12, 2021, 02:05:21 pm »
Hi Michael, thank You for the file.
Maybe in this case You dont need a macro? maybe simple generator will do the trick:
Hope this helps
Michael Betke
« Reply #6 on: March 13, 2021, 11:35:41 am »
Thanks! It's what I was looking for. :)
But somehow I thought the Roof Macro replaces the Array solution.
« Reply #7 on: March 15, 2021, 09:18:04 am »
Hi Michael,
the roofing macro is designed for tiles that are rotated slightly so that they overlap one another. When you increase the angle. the macro uses the tile's thickness to automatically calculate the top padding required. Your style is a little different because the tiles interlock rather than overlap, so in this case it wasn't suitable. I hope that helps.
Michael Betke
« Reply #8 on: March 15, 2021, 09:24:41 am »
Yes it helps. Thanks for your explanation. Have a nice day :)
