Author Topic: Am I missing something  (Read 6449 times)
bmlokesh
« on: October 25, 2017, 02:21:33 pm »
I am stuck on the glass partition wall system
Instead of creating partition walls with glass, doors and other technical details, thought do it with RC
I am now stuck on glass and the joint, if the silica joint detail is enabled glass is not showing up
am I missing out something please guide me
Re: Am I missing something
« Reply #1 on: October 25, 2017, 03:11:54 pm »
Hi.
Thanks for contacting us. Please see the attached file for a possible solution. I made the following changes.
- Rotated the segments so that they are aligned to the X/Y plane and reset the xforms. I find it's much easier to work this way than rotate the objects in the segment node.
- Remove the end caps from the vertical segments and placed them in the corner inputs
- Disable X Evenly > Extend to sides. This will allow the top and bottom rails to continue the full length of the spline without being broken up by the silicon seals.
- Changed Default mode to Scale.
Many Thanks,
