Author Topic: XSplineMatID - how to include both Corners  (Read 4852 times)
« on: January 11, 2019, 02:56:42 pm »
Hi Rokas,
How to set expression to return MatID for both Corners (Before and After segment)?
Thank you.
« Last Edit: January 11, 2019, 03:04:52 pm by Dragan »
Re: XSplineMatID - how to include both Corners
« Reply #1 on: January 11, 2019, 03:13:54 pm »
There are a lot of going on in Your scene. I am a bit lost in it.
Maybe there is a matter not only of expression but style/geometry itself.
Could You create a simpler scene with clearer expected final result.
« Reply #2 on: January 11, 2019, 03:31:20 pm »
Sure
I need  cylinder on both corners on spline ID3
tnx
« Reply #3 on: January 11, 2019, 03:39:40 pm »
from Your situation it seems like it has to be just number "3".
and something else has to be done to prevent it's effect in other places.
« Reply #4 on: January 11, 2019, 07:51:42 pm »
Since this is just a part of more complex generator it will be great to have expression Attribute that combine XSplineMatID and XSplineNextMadID so both corner vertex can be included/excluded.
Thank You for reply.
« Last Edit: January 12, 2019, 10:49:40 pm by Dragan »
« Reply #5 on: January 14, 2019, 09:47:03 am »
Is this what You are after:
return if(XSplineMatID==3 | XSplineNextMatID==3,3,1);
« Reply #6 on: January 14, 2019, 12:14:12 pm »
Yes Rokas, thank you, but that solution force me to track all potential ID separation. Imagine complex Spline with 35+ spline IDs.
If I go with logic that certain spline ID will carry some Geometry that  includes/excludes both border corners, expression Attribute that include/exclude those corners will be very helpful (no need for If expression...).
Hope you understand and it make any sense.
Best regards
« Reply #7 on: January 14, 2019, 02:30:58 pm »
Isn't that what You have asked in the first post?
I am a bit lost.
« Reply #8 on: January 14, 2019, 03:31:22 pm »
Yes, Rokas
Solution is great, I`m talking about adding a new Expression Attribute as ER.
Sorry for misunderstanding  ;)
