Author Topic: problem with evenly fence  (Read 3092 times)
oligophant
« on: November 10, 2016, 09:56:15 pm »
Hi, i want to make a fence with gaps. The module its 4000mm long, 50mm gap with each module. The module have one "foot" in the center and 4 "suns" distribuited equally in the module. I tried to compose in pairs and nested gradually the items with the compose operator but i dont get the results i want. Please help me with that.
Also, i would like to choose different modules lenghts, 2000mm, 1000mm and 500mm to fit my project needs. I attatch the scene.
NB: how could i "de-emmbed" the geometry on the example library?, i want to learn from those examples how they were made.
Arch Pedro A. Solano
FP 5.0.5
Vray 3.35.01|3DMax 2014 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
Follow us on facebook
Visit us on PSolano
Re: problem with evenly fence
« Reply #1 on: November 11, 2016, 12:32:14 pm »
I would suggest you to use a Sequence Operator wired to the Default slot. By setting the Counter value for the "Compose" node you can easily define the number of "sun" Segments (in the sample scene it's driven by the Random Parameter choosing values between 1 - 4). The gap is set by an empty Segment's Fixed Size (which can be exported, if wanted). Hope you'll find useful.
"... how could i "de-emmbed" the geometry on the example library?"
In the Style Editor's Tool-bar, there is a Extract Segment to a new object button for these purposes (the object is created at its original coordinates and RailClone uses it as the new source object, discarding references to the old one).
oligophant
« Reply #2 on: November 11, 2016, 06:28:53 pm »
Nice, i'll check this out. by the way, how could i set the counter value?, its an expresion?
thanks.
FP 5.0.5
Visit us on PSolano
« Reply #3 on: November 14, 2016, 10:36:09 am »
This value can be entered directly within the Sequence Operator or by exporting this parameter and wiring it to a Numeric Parameter mode for easy adjustment directly from the UI.
