Author Topic: Railclone windows - some questions  (Read 4651 times)
Mattias
« on: July 12, 2018, 11:14:38 am »
After using railclone for a while for simple things (and absolutely loving it), I wanted to do something a bit more complex.
I`m trying to create a parametric window style that suits my needs for architectural modelling.The window type (fixed/openable/open) is defined by de splines mat ID, so i can easily create more complex windows.
issue 1
I`m trying to create a border around the whole window (orange spline) with a 2s array, but the segment should be aligned like drawn in green. Any suggestions?
Issue 2
I really like to have the option to open some windows (defined by spline mat ID). In the picture I use the x rotation in de 2s array, but this obviously doesn`t work when i rotate the windows around the Z axis and is greyed out when i set the array to align to spline. Is this possible?
Thanks in advance,
Kind regards,
Mattias
Mattias
Re: Railclone windows - some questions
« Reply #1 on: July 13, 2018, 08:49:00 am »
Update:
I`ve found a way to do the border. But segments disappear depending on the spline size. I think other people have reported this behaviour too. See pic attached.
Opening the windows works too, since i can just rotate the spline associated with the openable window when setting the 2s array to align to spline.
Kind regards,
Mattias
« Reply #2 on: July 17, 2018, 09:10:16 am »
Update:
Please attach Your scene regarding disappearing segments.
Mattias
« Reply #3 on: August 01, 2018, 08:43:06 am »
Just back from holidays. File in attachment.
Kind regards.
« Reply #4 on: August 01, 2018, 10:20:20 am »
Thank You for the file. Issue confirmed. We will check what can be done.
Paulo R. Beck
« Reply #5 on: August 18, 2018, 04:02:58 pm »
I had a similar problem, when I switch off the panel in my window (That is a nest style)  my window frame disappears
« Reply #6 on: August 20, 2018, 02:41:02 pm »
Thing is You are placing objects outside clipping area borders. That is bad practice in RailClone.
You can use Linear generator for Window frame without this limitation.
