Author Topic: Classic molding frame How To  (Read 4200 times)
Serj Cataev
« on: September 04, 2016, 04:33:33 pm »
Hello. I'm trying to make a railclone object that creates  decorative wall frame. I've attached images where the problem is shown. Also there is a file.  I used Linear 1s generator - corner elements are getting messed up. Any suggestions how to get the desired result?
Regards.
Re: Classic molding frame How To
« Reply #1 on: September 05, 2016, 11:59:05 am »
As the corner Segment isn't symmetrical and needs to be mirrored, I would suggest you to pick the "corresponding one" by the Selector Operator in the Spline Mat ID mode. In attached possible solution vertical lines have the ID 1 assigned and horizontal lines ID 2.
Segments in attached style are using the Pivot Alignment and the precise placement is handled by using an empty Segment with Left & Right Padding values corresponding to corner Segment measurements.
Hope you'll find it useful.
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #2 on: September 05, 2016, 03:08:43 pm »
Hello Michal, sorry to hijack this post but how do you get this window in you first capture with the dimensions, etc. ?
« Reply #3 on: September 05, 2016, 04:06:27 pm »
No worries at all, it's the 3ds max's Measure utility (Utilities - Measure - New Floater).
Best regadrs,
Serj Cataev
« Reply #4 on: September 23, 2016, 11:50:23 pm »
Thank you for resolving my problem. :)
