Author Topic: railclonepro.dlo keeps crashing my 3Ds Max  (Read 31426 times)
quadrantatelier
« on: August 24, 2025, 05:59:35 pm »
Hi, I am working on a file,. This file has xref scenes in it.
It keeps constantly crashing my 3ds max, Most of the time at startup. Its driving me crazy. Can you please help me figure out how to fix it.
I have tried converting the files i have xreffed in, converting their railclone to editpoly. This hasnt worked. I am in urgent need of help as this has been going on for weeks since i started these projects.
I am not currently making some walls and fances with railclone.
This is also not the only file, i have 3 different files with different projects doing exactly the same thing with the same error. Please can you help me fix it. I will attach wetransfer  link with minidump files on this link, use the terrain model as the main file, i have included the xrefs> https://we.tl/t-TpMRMbASTb
I have updated 3dds max 2025. Updated latest forestpack and railclone. I have also a very good PC with 128gb of ram, 4090 GPU and 149000 CPU.
Re: railclonepro.dlo keeps crashing my 3Ds Max
« Reply #1 on: August 25, 2025, 09:15:36 am »
I'm sorry to hear that you're facing these issues. Unfortunately, after reviewing the provided minidump file, we weren’t able to identify an exact source of the problem — the error is too generic. We’ve tested the supplied scenes on several machines with different configurations, but so far we haven’t been able to reproduce the issue on our side.
Do you notice any other stability problems with your PC? We’ve heard reports that the i9-14900K can sometimes have instability issues, so it might be worth testing the same scenes on another machine if you can, just to compare.
Thanks a lot for keeping us posted, any extra info will definitely help.
quadrantatelier
« Reply #2 on: August 25, 2025, 06:19:05 pm »
hI,
I CANT REALLY TRY IT ON ANOTHER PC. i UNINSTALLED RAILCLONE AND NOW I GOT THE SAME CRASH BUT THIS TIME THE NAME IS MISSING, DOESENT SAY RAILCLONE, ITS JUST BLANK?
date/Time: 2025-08-25 17:17:41 +01:00
Application: 3dsmax.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name:
Exception Address: 0x0000026ccd9a8e20
Exception Code: c0000005
quadrantatelier
« Reply #3 on: August 28, 2025, 06:16:01 pm »
Im sorry but honestly something needs to be done for this railclone dlo . I cant work with it like this and i am not sure what else to do. Is there really nothing that can be done from your end? I have reinstalled 3ds max and plugins.
« Reply #4 on: August 29, 2025, 08:39:42 am »
According to your previous post, it also crashes with RailClone uninstalled. Please, can you confirm this ?
If so, there is not much we can do, because once uninstalled the plugin cannot be the cause of the crash. It seems a problem specific to your configuration or hardware.
In any case, please send us an updated minidump. We'll check if it provides us some new information.
