Author Topic: animating escalator??  (Read 8671 times)
scott
« on: March 16, 2015, 05:37:51 pm »
I can't find any info or figure out how to animate an escalator.  Is there an animate check box like in ForestPack?
Re: animating escalator??
« Reply #1 on: March 16, 2015, 06:01:31 pm »
Hi Scott,
Are you referring to the escalators from the included library?
scott
« Reply #2 on: March 16, 2015, 06:32:49 pm »
Yes exactly.  All my tests don't seem to work!  Tnx
scott
« Reply #3 on: March 16, 2015, 09:34:14 pm »
??  Anyone.  On a bit of a deadline here.  There doesn't seem to be any other posts about this....I must be missing something that's right in front of me!  Grrr.
« Reply #4 on: March 17, 2015, 09:48:44 am »
Apologies for the delay. To animate the escalators you can use the following steps:
  • Change the Default In/Out tangents for new keys option to Linear. This is to prevent 3ds Max automatically adding ease in and out to the animation.
  • Turn on AutoKey and animate the Parameters > Step Animation value from 0% at frame 0, to 100% at Frame 20 (for example). This value represents the animation of a single step
  • To make the animation loop, open Graph Editors > Track View - Curve Editor.... Select the animated track and set the Parameter Curves Out Of Range type to Cycle
  • To adjust the speed of the animation, just change the timing between the two keyframes
You should now have an escalator that with a looped step animation.
Many thanks,
« Last Edit: March 17, 2015, 09:55:38 am by Paul Roberts »
scott
« Reply #5 on: March 25, 2015, 03:09:39 am »
Hey Paul, really appreciate the help on this.  Worked like a charm.
Sorry I didn't come back before this. Tnx much.
