Author Topic: Fence not Adjusting to Surface  (Read 2411 times)
QJ4089
« on: August 13, 2017, 10:51:19 pm »
I created a Rail and Post fence and added a surface via the editor. Only the posts are adjusting to the surface; the panels are not even though the surface is applied to them as well. This is happening with both of the Rail and Post styles. All the other fence styles work as expected.
Re: Fence not Adjusting to Surface
« Reply #1 on: August 14, 2017, 12:58:00 pm »
Unfortunately, if X Rotation is used in the Array 2S Generator, the Surface feature will not behave correctly. We'll check, what can be done to improve it. As workaround you might find useful to conform the spline by using our Glue utility and use the "conformed spline".
Best regadrs,
« Last Edit: August 14, 2017, 01:17:55 pm by Michal Karmazín »
QJ4089
« Reply #2 on: August 22, 2017, 05:11:33 am »
Thanks, that worked.
