Author Topic: Wrong UVW box mapping rotation/direction  (Read 5254 times)
Mantas_Kava
« on: October 28, 2019, 05:28:19 pm »
How can I fix the rotation on the side so it goes along the red lines that I have marked?
I'm using RC's box mapping feature here. Tried rotating mapping but it rotates on the wrong direction.
Re: Wrong UVW box mapping rotation/direction
« Reply #1 on: October 28, 2019, 05:31:16 pm »
can we get Your maxfile RC style please?
Mantas_Kava
« Reply #2 on: October 28, 2019, 05:47:01 pm »
Sure. You just need the index.xml file, right? Or otherwise where exactly Style properties are stored at?
« Last Edit: October 28, 2019, 05:48:32 pm by Mantas_Kava »
« Reply #3 on: October 28, 2019, 05:53:28 pm »
Your max scene .max file. hopefully texture is not necessary i will plug any wood
Mantas_Kava
« Reply #4 on: October 28, 2019, 06:16:06 pm »
« Reply #5 on: October 29, 2019, 07:14:36 am »
Ok, rotation does not help in this case. As a workaround You can use Triplanar Map:
Mantas_Kava
« Reply #6 on: October 29, 2019, 02:31:52 pm »
Okay but this method breaks as soon as you add a second part to an equation.
These two parts has to have different directions, although they belong to the same RC object:
How do I do that then? Or is it not achievable using RailClone? which would be kinda surprising and disappointing at the same time.
Trying to create some wooden doors and windows here.
« Reply #8 on: October 30, 2019, 07:03:31 pm »
Hi - for maximum control (for example to have a different rotation on the end caps) I would set up a multi-sub object material that has the texture repeated 4 times, each rotated in 90-degree increments. You can then control the direction of the grain on the source geometry simply by switching the material IDs.
A sample file can be downloaded here: https://d.pr/f/hPHJhV
All the best,
« Reply #9 on: October 30, 2019, 09:33:10 pm »
I think we are expecting different results.
I still can't find a mapping solution for rotated segments.
https://we.tl/t-1Z7tnG6hu5
« Reply #10 on: October 31, 2019, 10:46:31 am »
Hi Dragan,
Yes, sorry. That was a reply to the previous question. I'm still taking a look at the rotated issue.
Cheers,
