Author Topic: Carreteras con Uniones e intersecciones en RailClone  (Read 2601 times)
LK4737
« on: May 17, 2021, 11:59:40 am »
Hola a todos, tengo una duda importante.
Llevamos varios días intentando crear carreteras, nuestro problema es que no encontramos la forma de generar uniones, intersecciones, etc (es decir, para crear carreteras secundarias que entran y salen de otras). Además, no encontramos documentación al respecto. Un saludo y mil gracias
Re: Carreteras con Uniones e intersecciones en RailClone
« Reply #1 on: May 17, 2021, 12:50:56 pm »
I'm afraid at present RailClone doesn't support joints or intersections. Usually this geometry problem it's difficult to solve even manually, because it requires boolean or other advanced operations. Typically for roads with complex layouts I'll create them simply by meshing closed splines, and then use the same spline to apply Curbs using RailClone.
