Author Topic: max segments warning - but I'm below limits  (Read 3064 times)
Rio
« on: July 22, 2021, 05:20:25 pm »
I keep getting the max segments warrning on this object, but stats tells me it's well below the limits I have set - 1380/50000
Am I totally misunderstanding what it's telling me?
Re: max segments warning - but I'm below limits
« Reply #1 on: July 23, 2021, 12:43:22 pm »
Do you only get this error while you're editing the spline? On occasions, I've seen occasional glitches when editing where RC momentarily creates more geometry.
Rio
« Reply #2 on: September 29, 2021, 06:09:25 pm »
Ok, so I've had a chance to have a closer look at this model. Don't judge me, I know the graph is a mess, blame the architect!
Segments only at 1277 for the exterior, but it's still kicking up a warning.
If you wouldn't mind having a quick look, Paul, and see if you can see anything obvious?
« Reply #3 on: October 01, 2021, 02:49:27 pm »
Thanks for the file. I've narrowed the issue down to the large bottom padding value used for the balcony segments. I'm not 100% sure why it should cause this error, but for now, I would recommend removing it. You can then add the Segments to the Generator's Bottom input and use the Y Fixed Translate value to move the geometry into position instead. Please see the attached file for an example.
I hope it helps.
Best,
Paul.
« Last Edit: October 01, 2021, 02:57:14 pm by Paul Roberts »
Rio
« Reply #4 on: October 04, 2021, 06:12:42 pm »
Excellent, thanks for that! Yes probably not an ideal methodology I'd used looking back at it.
