Author Topic: Apartment segments on corners that aren't at right angles  (Read 9191 times)
SJB
« on: October 09, 2025, 08:58:56 am »
Hey. Just wondering how best to do this. If I have balconies that are on corners of a building that are not right angles. I have found a way if they are at right angles, but I am not sure how to do it if they are not. Also, how do I make it that the segment is mirrored at the end before the corner? Thanks very much.
Re: Apartment segments on corners that aren't at right angles
« Reply #1 on: October 09, 2025, 12:55:21 pm »
Due to the relatively short corner radius compared to the width of the geometry, these parts are tricky to handle. A possible approach is to treat the vertical constructions in a separate Generator to avoid overlapping geometry, and fill the horizontal sections using the Offset Spline operator. Please find attached a modified version of your scene using this setup. I hope you find it helpful.
SJB
« Reply #2 on: October 14, 2025, 06:38:05 am »
Thanks. That seems to fix that issue.
