Author Topic: Apply one UVW mapping for whole RailClone Object  (Read 5418 times)
arch3d
    • arch3d.pl
« on: January 15, 2019, 12:26:25 pm »
I would like to have this option.
UWV mapping for whole rc object ( if so i can have same coords for all generators in style )
Even applying one UVW mapping for each generator would be nice
Best,
M
Re: Apply one UVW mapping for whole RailClone Object
« Reply #1 on: January 16, 2019, 09:20:59 am »
Hi, actually it can be done enabling Mapping for each one of the Segments.
Perhaps we would add a similar option for Generators, overriding the Segment value.
But sincerely, i don't like the idea of duplicating parameters, because that makes the interface and the plugin more complex.
arch3d
    • arch3d.pl
« Reply #2 on: January 17, 2019, 06:22:22 am »
Hi Carlos,
Sorry for late respond but i would like to explain my request. My whole object (screen_01) contains only few pieces of geometry. It was made before mascros :)
But to do this i have some complicated tree (screen_02) - some generators are repeted because i cant use from-->to  range (i can do conditionals for each segment but it is time consuming and complicate generators - fastest way is copy generators for desired mat. ID)
Even if i use xform each segment has same starting point in UV space - so if i drag point on spline i got visible repetitons (screen_03)
Now if i apply UV mapping for whole object modifier ignore previous UV's and i have desired effect - even if i change element lenght (generator in scale mode) i have still proper mapping (screen_05) because starting point for each element is in same place in UV space (screen_04).
I hope it sounds logical:)
« Last Edit: January 17, 2019, 06:31:45 am by arch3d »
« Reply #3 on: January 17, 2019, 10:59:42 am »
as a workaround You could use TriPlanar mapping:
Hope this helps.
arch3d
    • arch3d.pl
« Reply #4 on: January 17, 2019, 12:28:47 pm »
I was so focused how to do it in RC that i forgot to use my brain to solve it in different way :-[
That's the answer !
Thank you very much !
+600 for a tip :)
