Author Topic: skip objects  (Read 3242 times)
JI5496
skip objects
« on: February 18, 2021, 02:55:09 pm »
What is the best way to skip objects?
Im not sure if my setup is correct but I have found no other way yet. Please see the attached screenshot/file.
My curtain wall consists of 2 types of colums, a bigger and a smaller one. While the smaller one is simply generated with an evenly operation , the bigger one is only at every 3rd position. I managed to do that with the sequence operator.
The problem arises when I want to add another segment - the "cross" (red circle), which is also supposed to be at every 3rd (big) column. I thought - no problem, just use the Sequence operator again - this time with a "null object" but that does not work at all.
I read in the forums of other people having problems with that too. So, as of now I have a small box as placeholder object, to make the sequence operator work. But that can't really be the solution, right?
Have I missed something, there must be a better way.
Thank you!
Re: skip objects
« Reply #1 on: February 18, 2021, 10:19:45 pm »
Yeah  :( you cant use empty segments in Sequences. I hope this will be on the list for next release.
Re: skip objects
« Reply #2 on: February 19, 2021, 07:27:22 am »
It is on the list. Can't promise for next release though.
Re: skip objects
« Reply #3 on: February 19, 2021, 07:51:37 am »
 ;D ;D ;D ;D
Itoo never make promises but do all the tasks, eventually.
Adnan Malkoç
Re: skip objects
« Reply #4 on: February 19, 2021, 02:27:10 pm »
Oh my god! I spent my last 2 weeks completely on RC.
...but do all the tasks, eventually.
So I read "eventually" as "evenly" at first glance. I read it few times  :D
Re: skip objects
« Reply #5 on: February 19, 2021, 02:49:47 pm »
 :D :D :D :D :D
I know the feeling...
Re: skip objects
« Reply #6 on: February 19, 2021, 03:32:39 pm »
When you start referring to items around the house as Segments you know you've got problems   ;)
« Last Edit: February 19, 2021, 03:34:42 pm by Paul Roberts »
