Author Topic: Arithmetic Node with Evenly Count error  (Read 3216 times)
DM1462
« on: September 18, 2023, 02:30:52 pm »
I'm currently trying to set the number of my evenly count using the MatID of my spline, using a simple arithmetic node slotted to the generator parameter, but I only get one segment in return;
I have no such problem with the default count mode, but unfortunately this mode scales my segments;
any idea on how could I solve this without using the spline division+corner slot solution?
Thanks in advance
Re: Arithmetic Node with Evenly Count error
« Reply #1 on: September 20, 2023, 12:10:38 pm »
Thanks for the question. The A2S generator supports this, just use a Conditional node to restrict the segments to only 1 object on the Y axis. I've attached a sample file to illustrate a simplified setup.
DM1462
« Reply #2 on: September 25, 2023, 03:42:25 pm »
It worked, thanks!
