RailClone => RailClone Pro (*) => Topic started by: Macker on November 13, 2019, 05:56:08 pm
Hi guys, just following your video tutorial for building parametric windows, and I can't get the arithmetic node expression to work at all. I get the following error:
Parse error. Expected ')' or ',' in argument list at line 1:
if(YSplinePosition=0,3,
I've also tried copying and pasting from the text version of the tutorial with the same issue.
You are missing one parameter and you have to use `==`
Also you have to start with word Return folowing expression ...
Return
if(YSplinePosition==0,3,_);
https://docs.itoosoft.com/railclone/converting-railclone-2-styles-for-railclone-3
Thank you :)
Hm,
Managed to get rid of the parse error now by adding a parameter that is missing; but it still doesn't work. I'm following this directly from the railclone tutorial here https://www.itoosoft.com/tutorials/parameterise-windows?back=page%3D5%26tag%3Drailclone
Here's where I'm at with it
Hi Macker
Tutorial was created for RailClone v2. Expressions were greatly improved in RailClone v3.
The same expression in v3 is written like this:
return if(YSplinePosition==0,3,
if(YSplinePosition==1,1,
2));
