Author Topic: wood fence mapping  (Read 4167 times)
pixelplume
wood fence mapping
« on: July 26, 2016, 11:40:37 pm »
I hacked the "Wooden Posts with Barbed Wire" preset and got it to a point that I'm happy with. The only problem is that the mapping on the horizontal wood pieces differs on the inside and outside.
  • tried adding a uvw map to the base mesh and that didn't work
  • rotated the mapping in the segment and that just flipped the issue
« Last Edit: July 27, 2016, 12:41:20 am by pixelplume »
Re: wood fence mapping
« Reply #1 on: July 27, 2016, 10:12:02 am »
I would suggest you to double check the UV mapping of used Segment(s). If that's correct, please check if you're using the Properties - Mapping - Apply Box Mapping feature, which might override it. Optionally, you can rotate UV Coordinates of used Bitmap map as on attached screen-shot.
Hope that helps.
pixelplume
« Reply #2 on: July 28, 2016, 06:20:01 pm »
those techniques did not work but after I dug around a while I found that the faces on the geometry (fence board) had different material ID's! problem solved...thanks for your reply
