Author Topic: Default segments disappearing  (Read 2512 times)
PixelJockey
« on: January 07, 2020, 04:16:17 pm »
I'm creating a wood panel style with a clipping area that has trim boards on the top, bottom, start and end with default boards inside. It works until I add the top and bottom segments. When I do that the default segments disappear. I'm hoping there is a checkbox or something I'm missing. Any help would be greatly appreciated.
RC 4.1.1
Max 2018
Attached are a couple of screen captures and the Max file.
Re: Default segments disappearing
« Reply #1 on: January 07, 2020, 05:54:29 pm »
I had a similar issue.
As a workaround, I add another generator just for the Default segment and use `Border` Segment`s Size to make gaps.
Hope this solution can help you at the moment.
Best Regards.
« Reply #2 on: January 08, 2020, 08:46:51 am »
Yes, using 2 generators would be recommended solution. Thank You Dragan.
This happens because of how RC arrays work:
More detailed explanation is at our documentation page.
