Author Topic: Array 2S Corners  (Read 5388 times)
TCoote
Array 2S Corners
« on: April 04, 2018, 02:56:38 pm »
I've been trying to get this working this morning, and it seems so simple I'm sure I'm missing something extremely obvious.
I'm trying to use an Array 2S to wrap a facade around a volume, for use in matsterplan images. The problem is the corners either bend the geometry or extend it out of the bounds of the X Spline
I would also like to add a 500mm buffer from each corner, when the 2 segments that contain windows will not be placed - only brick. Would you be able to look at my file and let me know where I'm going wrong?
Re: Array 2S Corners
« Reply #1 on: April 05, 2018, 03:09:26 pm »
Hi TCoote,
Thank You for scene file.
Main settings that You need to adjust are "Array 2s" -> "Rules" tab -> X Corner:
Attached scene with modifications to check.
Hope that helps. Please write should You have more questions.
