Author Topic: array 2s extend x/y mat id  (Read 7000 times)
funk24
« on: August 04, 2014, 03:04:49 pm »
hello
extend x / y size to area does not work the limits by id.
greeting
funk24
Re: array 2s extend x/y mat id
« Reply #1 on: August 04, 2014, 03:12:03 pm »
Unfortunately it is not possible to use the materials IDs on Clipping paths with the limit to Material IDs option.  This is by design, Limit by material IDs is not intended for use with clipping areas and only works with X/Y splines.
This is because there are difficulties resolving a situation whereby a clipping path may have multiple IDs on the same spline, but also many users use clipping paths in conjunction with X/Y splines that may themselves use the limit by material IDs option to place segments.
I hope that helps to clarify this behaviour,
funk24
« Reply #2 on: August 04, 2014, 03:23:23 pm »
hi paul
thank you for the quick response.
greeting
funk24
