Author Topic: Feature Request - Select Object in Scene  (Read 6306 times)
a_nak
« on: February 14, 2018, 08:06:41 pm »
It would be helpful, if not already a supported feature i am unaware of, to be able to select all base geometry used in graph. or only select nodes. using something like a "select in scene" based on nodes selected or all geometry. this obviously would not work if the objects are 'embedded'.
Re: Feature Request - Select Object in Scene
« Reply #1 on: February 15, 2018, 08:44:39 am »
Hi, it can be done using the context menu (right click) with a RC object selected.
It works both for Segments and Base Objects.
a_nak
« Reply #2 on: February 15, 2018, 06:37:15 pm »
ah! brilliant! apologies for not reading about this feature.
Adam86
« Reply #3 on: February 22, 2018, 12:28:06 pm »
Adding to that (I didn't know about the above either so thank you!) what if you bring in a preset, currently objects are 'Embedded' how can we get an instance of this object  created when we hit this option you recommend above?
« Reply #4 on: February 22, 2018, 01:19:40 pm »
First you must export the embedded geometry to a Max object.
The procedure is described here.
Adam86
« Reply #5 on: February 22, 2018, 01:59:16 pm »
Amazing! thanks :)
