Author Topic: TRYING TO MAKE A FENCE, HAVING TROUBLE....  (Read 14130 times)
info@3deek.nl
« on: February 05, 2014, 12:26:09 pm »
I'm trying to make a wooden fence. The mapping has to be correct. The images will explain the problems. Max  file is included
Sorry, I'm not familiar with the terms for all the different parts.
Can some please give me some advice on how to overcome the problems mentioned in the images?
thanks in advance!
Cheers
Deek
Re: TRYING TO MAKE A FENCE, HAVING TROUBLE....
« Reply #1 on: February 05, 2014, 05:34:48 pm »
Hi Deek,
Please find an attached file with some possible solutions to the problems you illustrated in your screen grabs as follows:
UV Mapping - There is occasionally an issue with automatic box UV mapping bridging segments in different inputs. To work around this I've restructured your style to avoid the problem by using geometry only in the default inputs for horizontal elements.
Sliced Geometry - Setting the default mode to adaptive will automatically scale segments slightly to ensure no slicing takes place
Incorrect geometry on corners - unfortunately this is a limitation of this kind of joinery, it wouldn't be possible to create this joint with a simple mitre in real life. This kind of joint would only really work with handrail with a circular cross-section or other profiles where there is no need for a particular face to stay pointing upwards. One way of solving this would be to come out horizontally immediately after the 90 degree bend and then angle downwards. Alternatively create a wreathed handrail style that that will create a continuous curve to follow the complex angle. Which approach you take depends on the style of handrail you're trying to create. The file attached uses the latter technique.
Hope that helps,
Many thanks,
info@3deek.nl
« Reply #2 on: February 11, 2014, 11:58:39 am »
Hi Frank,
sorry for my late reply. Thanks for the suggestions! I will dive in to it!
Cheers!
Deek
