Author Topic: Array 2S1 Sequence stack causes uncontrolled offset of geometry  (Read 2522 times)
Piotr
Array 2S1 Sequence stack causes uncontrolled offset of geometry on axis  X just around the second vertex.
It happens regardless the spline is closed or open.
Re: Array 2S1 Sequence stack causes uncontrolled offset of geometry
« Reply #1 on: December 30, 2021, 01:41:17 pm »
Hi Piotr,
Could you let me know which version of RailClone you are using please, and if possible would you mind sharing that scene file?
Many thanks,
Piotr
« Reply #2 on: December 30, 2021, 01:47:04 pm »
Hi Paul,
Thanks for the prompt reply.
I use the RailClone Pro 5.0.7
Here is the scene.
« Reply #3 on: December 30, 2021, 02:59:58 pm »
Thanks for the scene file. Something appears to be amiss here, I suspect a bug so we're going to have to take a closer look and get back to you. In the meantime, you may be able to get around it by using a compose operator instead of a Sequence (although adaptive mode still appears to cause issues).
One way to avoid this completely by using the Start, End, Corner and X Evenly inputs to create the pattern instead of using sequence operators for the X axis. This would probably be my preferred approach anyway.
Apologies for the inconvenience, I'll let you know once we have learned more.
Best,
