Author Topic: How to place objects based on the size of closed Spline  (Read 2628 times)
Grey_Rift
« on: October 15, 2019, 01:42:11 pm »
Hey Guys,
I want to create a railclone that places different buildings depending on the size of the spline.
Using the Conditional operator didn't seem to do anything.
I believe this is because the conditional only read open splines ( I could be wrong about this).
I've added the graph with the conditional statement as an attachment.
After this didn't work I tried to write my own macro that would compare the surface of the spline and if the Spline had a bigger surface than the input number it would put the other building. But this didn't work either. An image has been attached to post aswell with the formula that I used.
Can anyone help me achieve my goal?
Re: How to place objects based on the size of closed Spline
« Reply #1 on: October 17, 2019, 09:32:57 am »
I have constructed a simple scene where segment is chosen depending on area size:
Hope this helps
« Reply #2 on: October 17, 2019, 09:46:43 am »
it would be „safer“ to check both lengths instead of the area - for example by the following expression, where exported X Size & Y Size attributes of the Segment are being used to evaluates if it fits or not:
return if(XSplineLength>Input1 && YSplineLength>Input2,2,1);
