Author Topic: Array on a curved surface  (Read 3214 times)
VanWijnen
« on: October 15, 2019, 03:58:01 pm »
I've created a RC object that turns a simple rectangle into a brick street. I can't seem to figure out how to use this RC object on the same surface / spline with a slight curve in it. The Linear1S part works just fine but the Array2S not so much. Could you please point out what I'm doing wrong? I've looked at a lot of tutorials and other threads but I couldn't deduce the answer there.
Re: Array on a curved surface
« Reply #1 on: October 15, 2019, 04:21:34 pm »
Try to make the surface slightly larger than the clipping spline.
« Last Edit: October 15, 2019, 04:52:54 pm by Dragan »
VanWijnen
« Reply #2 on: October 16, 2019, 07:22:28 am »
Hi Dragan,
Thanks for the tip! This does bring me closer but it messes the edges up a bit. Any clue on how to fix that?
(Also, apparently the surface has to be in the same postition as the spline to get the right curve)
« Reply #3 on: October 16, 2019, 08:11:20 am »
Raising the Clipping Area > Expand value should fix it.
VanWijnen
« Reply #4 on: October 16, 2019, 08:33:38 am »
That fixed it Michal, thanks!
