Author Topic: opening style editor shows dll error 126  (Read 6187 times)
link3d
« on: January 15, 2015, 12:28:08 pm »
railclone pro - opening style editor shows dll error 126 here
everything else running fine.
already tried to repair/reinstall the Visual C++ 2010 SP1 Redistributable Package thing.... didn´t help.
win7-64
3dsmax2015sp3
railclone 2.3.4
forest 4.3.6
vray 3.10.02
please help!
Matthias
Re: opening style editor shows dll error 126
« Reply #1 on: January 15, 2015, 04:06:17 pm »
For Max 2015, you need to install the Visual C++ 2012 Update 4 redistributable package.
Our entry FAQ regarding this issue was not updated with 2015. Apologies by that, i've just updated it.
link3d
« Reply #2 on: January 15, 2015, 04:59:11 pm »
hmmm, uninstalled c++2012 x86 and x32, uninstalled railclone, reinstalled everything, still same error!
we have three machines, with the same configuration.
(win7x64, 3dsmax2015sp3, vray31002, Railclone 234, Forest 436)
the other two machines are running fine....
Matthias
« Reply #3 on: January 15, 2015, 05:48:12 pm »
Please, do this:
1) Get Dependency Walker tool from here.
2) Run it. Select Configure Module Search Order from the main menu.
3) Click Browse, select the Max 2015 root folder, accept and click Add Directory. Close with Ok.
4) Open file, select RCEdit.dll in the Max 2015 root folder.
5) Once complete the analysis, save the result with Save as, selecting Dependency Walker image (*.dwi) format.
6) Repeat saving the result as Text (.txt) format.
7) Put both files (RCedit.dwi and RCEdit.txt) in a zip file and send it to support@itoosoft.com.
« Reply #4 on: January 16, 2015, 09:48:10 am »
Thanks for the files. It seems there are several missing libraries (i highlighted them in the attached screenshot).
Usually these libraries are copied by the setup program, but please try copying them from other workstation. You can find the DLLs in the Max root folder, and must be copied in that location.
