Author Topic: Object with multiple Array 2S Generators - one Generator only 50% Pathlength ?  (Read 4809 times)
suppenhuhn
my RC-Object is using multiple Array 2S Generators. I got stuck on the part when one A2S generator should follow the path only to the middle ( 50% of path-length ).
Now i'm dealing with it and add a padding right to this A2S manually - is there a way to solve this automatically ?
Thanks in advance:)
« Last Edit: March 05, 2018, 01:33:58 pm by suppenhuhn »
Using the Conditional Operator in the Position on Spline - Less than 50% mode should do the trick. Also, you can get the desired value based on the measurement of the following expression within the Arithmetic Operator:
return XSectionLength;
Once divided as needed (in your case by two) it can drive the Right Padding value of a Transform Operator wired to the Right Side Input. Attaching sample scenes. Hope you'll find them useful.
« Last Edit: March 06, 2018, 04:36:17 pm by Michal Karmazín »
suppenhuhn
Tahnk you so much!!! Awesome support as usual  :)
