Author Topic: Brick wall - Stack bond pattern  (Read 2757 times)
LC3D
« on: April 02, 2023, 05:57:06 am »
Is there a macro or similar for a stack bond brick wall? one that will do 90 degree corners and possibly have cut out sections for doors/windows?
I've tried with an A2S but cant get it to work with holes for windows doors or the corners...?
Any help is greatly appeciated.
Thanks.
Re: Brick wall - Stack bond pattern
« Reply #1 on: April 03, 2023, 10:06:11 am »
You might find the "RailClone for Brick Walls" thread interesting and helpful. For Doors & Windows, using a Clipping area within the Generator should do the trick - the Clipping area mode should be set to the Exclude mode and Projection to X or Y (as needed).
